Problem of the day!
Last night I was driving home from work, a bit spirited I might add, and when I was on the highway, cruise set at 65, I swear it just shut off. (The cruise, as if I hit the brake or hit cancel)
I very well MAY have hit cancel instead of the radio buttons I was trying to press, but I really don't recall hitting it. Anyways, I looked down like WTF! Why is the engine dying!? (Thinking cruise was still on, why am I slowing down, and RPMs are dropping)
I hit the gas pedal and it took off like normal, then I realized the cruise wasn't engaged. This could all be just a big coincidence and I hit cancel and didn't realize it.
So then, closer to home, my message center displays "CHECK ADVANCETRAC" and the ABS/Trac Control light came on. (Also, the light on the button was on, indicating the system was off) On my exit ramp, I shut the car off, started it back up, just the ABS light was on and as soon as I started moving, the light went out. All was well the rest of the way home.
So today I went to meet someone at Kroger, no lights. Left Kroger, went to the carwash and washed it, no lights. Got up to speed, message came on. Sometime later, the ABS light stayed on, but the traction control light (Little tire spinning, top center in the cluster) went out, beeped and said AdvanceTrac On.
I haven't narrowed it down much, but it seems like the car has to be moving. Like if I went out and started the car, it probably wouldn't be on, but then after I started moving, it would eventually show up. Im thinking it has to be a bad sensor, OR could it possibly be my uneven tire wear? Like one rear tire being worn more, and causing the system to see a difference in wheel speed with the other wheels? (I ask because I have some camber in the back from what im assuming is the ungodly worn toe-links, so im sure that tire is wearing much more than the other which is straight)
