2004 ls v8
only the drivers side window switch will work.
i have checked all fuses
everything else works.express up and down on both front windows work with drivers side switch, i can roll all the windows up and down using the key in the driver side door lock, both door lock switches work, the roof operates flawlessly , all functions of the key pad work properly. i have tried a different drivers side window switch thinking maybe the window lock has stuck in the on position, but no change.
so my question is , i guess, does this sound like a need to reprogram or replace the REM?
is the REM even reprogrammable?
any help would be appreciated and thank you in advance
