dertyclown
I got a data distance problem, some time my MPH does not work, ant the OD is ---------. any help would be grate
dertyclown said:I got a data distance problem, some time my MPH does not work, ant the OD is ---------. any help would be grate
97benchmark said:The problem is your abs/tc pump. All data is gathered from your wheel sensor, funneled through the abs and sent to the computer. First try cleaning the connections at the abs pump. It is in the front wheel well under the battery. Have you had it checked for codes? If I remember correctly the typical autozone code reader won't read the abs, you have to go to lincoln for that. Is your abs/tc light on? Mine said "distance data error" in the message center. It began with "check traction control" in the MC at about 10 mph and the abs light came on. I unpluged the connector (it was badly corroded) and cleaned it. After cleaning what was left I got the distance data error. I had to replace the pump assembly. They are not available rebuilt, new (discontinued) was 2000.00, junkyard 150.00. Remember, the abs pump has a special way to be blead to eliminate air. Standard bleeding won't work.
I believe he speaks hangoverish, LOL! :Beer97benchmark said:BTW dertyclown, did your last reply contain any english?
holly SH!T that is funny as hell I was really fu#ked up on that one. ha ha ha Ill try to sober up for the next oneKbob said:I believe he speaks hangoverish, LOL! :Beer
