Problems hooking up wet kit
Dern Humpus
Warrensburg, MO
I have my NOS wet kit fully installed on my mark viii and i went to test to make sure that it was getting fuel. When i first open the solenoids at idle (bottle closed) the fuel line didnt spray any fuel out and was actually a vacuum.
My friend also suggested that I could possibly have a variable speed fuel pump so I put a rag over the end of the line going out of the fuel solenoid and drove it at WOT with the switch on and the rag didnt get a drop of fuel on it. After nothing happened there I figured that I could possibly need a pill in the nozzle to get enough pressure the build up so the fuel would go through the solenoid, but that didnt work either.
Since there is a vacuum in the line when the switch is flipped and it stops when the switch is turned off then the solenoid must be opening, the nitrous noid works, I sent some nitrous through the line and it came out fine.
What gives?
well the no2 kicks up the fuel pressure( at least on my dry kit) you might need to have the bottle open but I guess it wouldnt be easy to test. Call the hot line they are freakin awsome
i used the fuel pressure test port with an adapter
check pm's Derm
