Problems Installing The New 3-Row Radiator
Sifrino3
Prescott Valley, Arizona
The top mount brackets do not fit. Whats up with that? Where do I have to find the new ones at?
NYC LSC Have you had problems with this?
Didn't see this thread until way after your PM. Sorry. But yeah, you need to trim the rubber inside the bracket to go over the larger radiator. Sounds like you figured it out.
Yep, all good. But now the water pump is leaking onto the timing cover. . . So, more and more time to put into Sifrino!
My overheating was due to the radaitor. It was restricting the fluid like crazy. Water pump is good though. But Im still changing it out for the high performance one. . .
What a difference from the 3-row over the stock. DAMN!
You did use the black silicone with the gasket, right? I did and mine doesn't leak a drop.
Remind me which 3-row radiator you boys are using.
I need a little more cooling power now.
Yours,
MACHVII
NYC LSC said:
Mine - and I think his, too - is the 3 row from AutoZone.
Thanks, Tommy. I found the info you handed out in a previous post (PN#433138 Three Row w/ Max Cooling & Heavy Duty).
Yours,
MACHVII
