snip
I am going to go with a new radiator and reroute the line from the reservoir to the tank bc it runs inbetween the radiator and the "cant think of it" right now but I am still wondering about the ta ta ta ta noise from the car when first started in the morning,... snip
In stock configuration, the way the vacuum/return hose was stretched tight and took a sharp U-turn off the radiator cap nozzle bothered me, so I rerouted mine, coming up from below the nozzle, using twist ties to secure it. The hose is a couple inches longer than it has to be and allows a bit of leeway. The U-turn can be straightened a little.
If that hose leaks (air or water) or is kinked or clogged, the overflow tanks' function (added cooling capacity) is sacrificed.. so it deserves some attention, imo.
As for that noise...
I'd have someone else start the car and try and determine where it originates. If it's loud it may be external to the engine, meaning something is hitting something.. and it's location might be obvious.
If it's internal then.. well... i guess you get a engine stethoscope (length of garden hose?) and try and narrow it down to a general area.. Since it goes away fast, if internal it may be due to lack of initial lubrication.
To show how one thing may lead to another along a very strange pathway, I had a similar noise and it was due to a suspension problem.. lemme explain that.
My air springs were leaking. The front end often "deflated" and dropped down very low, sometimes while parked with the front end over a curb or concrete wheel stop (like in parking lots).
Front end drops, hits that curb and bends the fan cowl. It's plastic so it springs back for the most part, but not all the way.
Anyhow, the one blade of the fan that is slightly longer than the others would bang against the cowl's bottom with a loud tap-tap-tap when starting, then go away as everything loosened up a little.
After fixing the air springs, a little pressure on the sides of the cowl rounded it out enough to eliminate that noise.
Noises are difficult to source remotely.. since you have the car, nobody is better suited for the job. Front, left engine? Right rear? Centered over the intake? Share that info and people here might be able to suggest a next step.
So, there's another 200 words or so that could be condensed down to 6 or 8 if I tried.. but I won't.
