Professional Products Fuel Pressure Regulator???
Silent Assassin
Edinburg
I've been searching high and low for any information on the Professional Products Powerflow Fuel Pressure Regulator part # 10681 and can't seem to find anything. Anyone have any insight on these things. Apparently, they fit 1994-'95 5.0L Mustang & Cobra, 1994-'98 3.8L Mustang, 1996-'97 4.6L 2V & 1996-'98 4.6L 4V Mustang & Cobra, so I'm guessing they will also work on the Mark 8s, but are not listed. They can be had for $73.95, which is $53 less than the Aeromotive.
Fuel: Gasoline/Alcohol
Pressure Range (psi): 25-75
Regulator Style: Rail mount return style
Regulator Location: Fuel rail mount
Boost/Vacuum Reference Port: Yes
Boost/Vacuum Rise Ratio: 1:1
Gauge Port: No
Mounting Bracket Included: No
Fittings Included: No
Rebuildable: Yes
Inlet Attachment: Stock
Outlet Attachment: Stock
Return Attachment: Stock
Regulator Material: Billet aluminum
Regulator Finish: Natural
Notes: For use with stock or aftermarket fuel rails.
Professional Products Powerflow fuel pressure regulators are designed to help provide stable fuel pressure under the most demanding conditions. These pressure regulators allow multiple fuel pressure adjustments for increased volume, resulting in better overall performance for your vehicle. Professional Products offers these Powerflow fuel pressure regulators in a number of styles and applications to suit your vehicle's needs.
Anyone running one of these? Any input welcomed. :)
Look at the Kirban one. Fits in tight hood spots like mk8. I got one and it works fine.
Do you have any need for one or do you just want to throw away your money on something you think you might need?
That just looks like a repackaged Kirban.
so be it, if it is. it is 10% off and shipping is included. like $99 to your door. and great customer service. you can reach him on here he is onebadmk8 . he makes the cobrastars and supports this and every other mark cite
I do not get into the politics of where peeps should buy. I am commenting on the product only.
I think I have one new in the package. I can check in the morning if you're interested in it.
