Pulling to the right
PeteyCracks
South Florida
I just a wheel alignment on my 2000 Conti because it was pulling to the right pretty hard. The alignment didn't change it much but the mechanic said I'm also gonna need new sway bar links soon. Could that be why it's still pulling to the right or is there some other factors at play?
Check your brakes for dragging and/or tire pressures.
If you are experiencing excessive torque steer, your inner tie rods need to be replaced.
Did you have an inspection done on front end components before getting alignment done?
Sway bar links do not cause pulling, they only make bumping/banging noises if they are broken.
Got it inspected yesterday.
The diagnosis: Sway bar links are bad, front struts are bad, and rack & pinion are bad.
