PVC hold/dissipate charge?
NickLS
Houston, Texas
Quick Easy to answer question:
Does air rushing through (the interior) of a PVC pipe cause an electric charge to form?
It's very easy to create staic with PVC. With just air I don't know, but other items like nylon, silk, and different typs of fabric it's pretty easy.
I'm making a heat shield for my True-Rev intake for my 01 LS, I don't have the $$$ to buy the LLSOC air tube so I'm using stock.. With the stock airtube, the filter sits about 3-4 inches from the engine. With me building a heat shield, I want the filter to be further away from the engine and dip down towards the air hole that the stock airbox used. So far the extension is a work of art, but is made of PVC pipe... I know that rubbing it with a charged material such as wool, fur, nylon, etc. creates a charge on the OUTSIDE surface of the tube but I don't think it's on the outside.. Either way, I wanted to know since the MAF sensor (which the filter is connected to) attached to the pipe, and I don't want a discharge (if one ever occurs) to fry the sensor.
I was thinking, just in case the 1 in a million chances, that a charge does build up, that I ground the pipe by screwing a small screw into the pipe, then attach a wire from the screw to the frame, thus grounding.
Any thoughts? Cause if this works like I want it to work: Heat shield HERE I COME!!
If I were going to fabricate something like that I think I would use a small metal pipe such as rigid dryer vent. It's probably lighter than the PVC and it probably costs less.
I'm not sure a grounding strap will work on a non conductive material. Static isn't like electricity. It's a charge that builds up on the surface rather than a flow through the material.
Also, now this is a shot in the dark, but overtime I could possibly see the PVC giving off fumes from surrounding heat and giving a sensor bad readings.
I was thinking of using a dryer vent, but the vent is too flimsy... I just want to make the filter move away another 4 inches and dip down about 22.5 degrees. I found a PVC pipe from home dopot that is a does exactly this.. so I'm gonna go with that.. If not, I'm out $2.50. :)
Here's something, whiile I was wandering around I came across some Heat resistant grill paint that you can use on your grills. Supposidly resistant to temps up to 1000 degs. so maybe if I spray the tube, it will become alittle more resistant to wear and tear from the heat. Any thoughts?
You're thinking too much. Put the PVC in.
Many others have similar with no ill effects. I have an aftermarket CAI in my Mark VIII which is essentially made from PVC fittings.
I hadn't thought of paint but if static is the concern, I think paint will eliminate that problem.
Hey guys, this issue came up on Myth Busters not too long ago. They tried all kinds of things to get a static charge but the PVC wouldn't hold it long enought to create a spark.
