DaleGrib
I have a question about the A/C system on the LS. When I have the air set to 60 the fan seems to put out the correct amounts of air on whatever setting you set the fan to. However, as you start to raise the temp to say around 65-68 you start to notice a decrease in the amount of air coming out the vents. Is this normal or does anyone have any idea as to why this is happening? I know the A/C compressor does leak in this car as I can see the green dye but it's fully charged right now. I was going to have the compressor replaced before the summertime so is there a possibility the compressor could be causing this? I also just replaced the cabin air filter to make sure that was not apart of the issue and the old filter was pretty clean already but still went ahead and changed it as it did look old and obviously that did not make any difference being the other filter was pretty clean. I mean I guess the level of the refrigerant could be low as there is a leak but just wondering in general what could cause the issue of less air coming out on a higher temp setting.
