MCTIM_00LS
I WAS THINKING OF DOING THIS SET UP IN MY 2000 LS. I WAS WOUNDERING IF ANYONE HAS HERD ANYTHING ABOUT THIS INTAKE? ALSO WANTED TO KNOW WHAT EVERYONE THOUGHT ABOUT THIS? HERE IS THE INFO FROM K&N FOR THE INTAKE.
The K&N Apollo CIS (Cold Intake System) is a universal cold air intake system incorporating a washable/reusable K&N High-Flow Air Filter. The Apollo’s specially designed shape increases volumetric efficiency and provides the benefits of an open cone filter and standard air box in one unit. Heat build up is reduced which keeps the intake charge cool. Smooth internal features minimize air turbulence and maximize air flow.
The Apollo has a 70mm base flange. It is supplied with a flexi cold air hose and a pack of vent adaptors to incorporate most engine breathers and temperature sensors from the original air box assembly back into the Apollo (Vent sizes ¼” OD, 3/8” OD, ½” OD, 5/8” OD and a blanking plug if a vent adaptor is not required are included). Additional accessories include a range of stepped adaptors from 70mm – 70mm (part 85-6002), 70mm - 60mm (part 85-6003), and 70mm - 80mm (part 85-6001). A saddle bracket kit (part 85-6004) for easy mounting to your vehicle is also available.
The Apollo is ideal for normally aspired engines up to 250BHP and turbo engines up to 350BHP. It allows for updating your intake system while retaining a closed environment.
