Question about Wiring Harnass for the Angel Eyes
alternativeguy17
Centralia
I recently purchased the Angel Eyes on ebay, since i saw that Ken was out of stock on his...My question is though since i wasn't able to get a pre-wired set, how hard is it going to be to wire it up, or maybe i can find a place that sells this....comments, or anything helpful wise is appreciated....thx
There is a guy on ebay that sells the harness I just dont know if he sells them seperate from the Angel Eyes! I think he sells it for 49 dollars, email him and see if he'll sell you just the harness. Here is his e mail address: pro-choice-kustomz@cox.net, I've never bought anything from him but his feedback on ebay isn't bad!
That's the same guy i bought the Angel Eyes from actually...Just he's out of the pre-wirred...He says that hurricane that went thru folrida has thrown him off of completing any lately...So i'd have to wait a good month or two if i bought from him
oh ok I see!! Sorry For not being any help! :Bang
Well, I don't believe that. Typically when I purchase used headlights I get the entire unit which includes bulbs and the wiring harness. He does the exact same thing. However, there is a dry run on headlights with the factory wiring harnesses. I'm currently out of stock of angel eye rings and I may have two sets of wiring harnesses I can use for orders. After that I may have to just sell the headlights without the harnesses. If you want to hook up the wires yourself here is how:
If you want to pre-wire the angel eyes to your parking lights you will need to tap the hot (+) wire from the ballast to the Orange/Blue wire from the OEM wiring harness. Then tap the ground (-) wire from the ballast to the Black/Blue wire from the OEM wiring harness. After that just plug in the wires from the rings into the connectors from the ballast.
If you want to put your angel eyes on a 12V switch inside the car just connect the hot and ground from the ballasts to a switch of your choice. The hook up on these are extremely easy and if you purchase a set of angel eye headlights not pre-wired I send a wiring installation guide with each set.
I hope that helps.
Thanks for the info guys...I'm still waiting on the lights to come in yet...but i'll try what ken said and try hooking them up to the parking lights, my only question is then does the angel eye's switch on and off the same way the parking lights do, and will the auto timmer work for the angel eyes to
Keep me posted on how the angel eyes look when you get them!!
Your angel eyes will come on everytime the parking lights are turned on if you wire it up like I mentioned above. It will also come one with the timer set too.
