GMAN
I'm going to go with the factory amp until she gives out. What's the ideal wire to tap into for the amp turn on?
Dude, if you are using a Pioneer then bypass the amp or it will make horriable sounds when it turns on and off.
If you insist on using it then just get the adapter harness...... not the one with RCAs either unless its a deck with 5v or more RCA output.
Its more their NAV decks that do it due to the LCD screen.I must've gotten lucky then. My Pioneer doesnt make any kinda noises when it turns on or off. I have the JBL system too. I am running the Scosche FAI-3A Gain Adjuster though.
Like said above if you are using the harness you buy at the store(I prefer getting them at Wal-Mart since they are only 8 bucks) just hook up the blue wire to the stereo's power antenna wire. If I remember correctly there are two ground wires that need hooked up too. One for the radio, one for the amp. Just hook them to the same ground.
I think G just wants to connect another amp up to the factory amp for power only for maybe a sub. That's how I was reading it but I could have it wrong.
Huh, I did not know that.IIRC the factory amp turn on signal is only 5v and wont trigger most after market amps
