Radio Wiring color breakdown?
jrhartman
Topless Member
Livonia
I need to know which wires on the standard radio in a '97 are the Constant, Aux and the Ground....I am sure I can figure it out, but instead of guessing I wondered if anyone has the wiring diagram on line?
Thanks
Do you have the luxury system or the JBL system?
99% of the time in newer cars this is the color code
RED - Switched power
YELLOW - Constant Power
BLUE - Power Antenna
BLUE/WHITE - Amp Remote or Accessory turn-on lead
BLACK - Ground
ORANGE - Dimmer
GRAY - Front Right
WHITE - Front Left
VIOLET - Rear Right
GREEN - Rear Left
what they hell kind of radio is in this thing??? I pulled it out with then intentions of adding an aftermarket cd changer and I couldn't find an antenna plug????? did I miss something or is there really no antenna plug???
antenae crap
your ant. is in the trunk it is integrated into the tuner.the easiest way to fix this without poping your backseat out is to buy a powered unit they are about 20 bucks and you hook it up to the power ant.wire off your stereo and other questions let me know i just did whole overhaul of my sound sys.
Staff online
