Right on the Mark
Starting the end year push with Red Dragon again. Needed to install these to run the Weld Prostars on the rear. Already redrilled hubs to 4.500 last year. The new studs knurl dia is .595 so drill size needs to be .580 which is 37/64. Could they pick any weirder of sizes for these things there all that way no standard drill sizes to install them.
I made new redrill fixture because old one would not allow 37/64 bit.I made drill guide whole length of drill to support 100%.
Fixture on. I needed the studs 100% correct spot because Welds are stud centric.
Studs go in no problem, just have to slip them into hub thru the area where the caliper was.
I cannot stress using good drills. My new chicago/lithtrobe USA drill cut thru like butter. USA USA.
