Rear Brake pad- removal
Frat-man-du
Gainesville
Do you really need to "Remove the rear disc brake caliper flow bolt?"
This require a bleed of the system.
I need to replace the rotors and pads and according the Lincoln Manual this is the way to go. I have done my T-Bird, Mustang and Ford E-150 and never had to bleed the system for pads and / or rotor replace.
Any thoughts gang?
Pads and rotor replacement should require bleeding the system.
I have never bled the brakes when replacing the pads. you don't need to if you don't open the bleeders. all I do is use a turkey baster to remove some brake fluid from the master cylinder so when you compress the calipers it doesn't overflow. I just did the brakes my on my Mark and they work great.
Oh that's why they tell you to do that. I always pull out the old fluid and put in fresh and then let the bleeders gravity drip for a bit, then top off .
yeah, when I'm done with replacing the pads, I remove all the old brake fluid I can from the resovoir and put new Valvoline synthetic brake fluid in the resovoir.
