TunerdusterVII
Will a rear end from an 87-88 thunderbird turbo coupe work on a 1990 lincoln mark vii lsc?
all factory 8.8 housings are physically the same, is the tbird disc brakes, does it have abs, these are questions which will affect axle length and the sort which is where problems will lie
Why are you swapping it out in the first place? Plenty of lincoln rears out there to be found cheap..and thats what most people do, not the other way around.
You could just swap carriers, you know?
