It's probably pretty close to the 98. In the 98 you need to remove the lower part of the sear first.
First push down and back on the bottom part of the seat to make it slide off its lower brackets (which are at the front of the seat). Then as you continue to push back pull the front part of the seat straight up. This will remove the bottom.
Next you will see at least two harnesses that bolt underneath the rear bottom seat and attach to the back of the rear seat (the 98 has two). Remove the two bolts and then push up and back on the the seat back and it should slide up and release from the top brackets.
Reverse to reinstall. Just becareful not to stip the bolts on the harnesses as they are directly bolted into the floor pan of the car.
This may vary slightly model to model, but is probably pretty close to the same.
