Rear Speakers
JERSEYJOE
KEARNY, NJ
My 93 VIII has got some crackling rear speakers. My question: Are there any aftermarket bolt ins or do I need to find used ones? I would rather not have to " Make them fit."
Second part: if used is the way to go I need at least one tweeter and the larger one for the rear left.
If you want to stick with close to what you have, just buy a pair of 6 X 8 speakers without tweeters on them. Don't go back with stock because you're looking at 11 to 16 year old speakers. You also don't need to get anything expensive or rated high in power to work with your stock system. 5X7 - 6X8 will be a direct fit for the rear and for the doors. The link below has some that would fit perfect for you and still be stock but newer!
http://cgi.ebay.com/ebaymotors/NEW-...c9461acQQitemZ120470135212QQptZCarQ5fSpeakers
2nd part, the tweeter may be what you hear cracking but if not, all you need is the single speaker. I would change both on each side though. Only takes 10 minutes.
i just replaced mine, if you want my stock one's pm me. You can have them if it helps. There was nothing wrong with them.
