Does anybody have any information about rear tire wear for the 2000 LS? Both of my rear tires are worn pretty good at the center of the tire, with the edges being so so. I do know that over inflation will cause this, and is probably the answer. However my local tire shop claims to have seen several LSs with similar rear wear. They only way they can claim to make even wear is to put about 20-25 PSI in the rear tires. I'm not sold on that idea in the least. The car tracks well, and does't pull under accel or deccel, so I don't think alignment is the problem. This is my first 4 wheel independent suspension car, so I'm wondering if this is normal or just BS, and the guy before me had way too much air in the tires... Thanks Gang!
Kleetus
'00 LS V8 Sport
Kleetus
'00 LS V8 Sport
