Rear Window Malfunction
jamhow
Was rolling the right rear window up tonight on my 01 and POP! The window won't go up. The motor will still run and the window will slide up and down if I grab it and pull up.
It was dark so I didn't look it over real good, but I presume I need to remove a few screws and the inside cover of the door will come off so I can take a look? Anything there I may tear up if I don't know what I am doing and what should I look for once I get there--broken track or plastic tab or something like that? Would appreciate hearing from a voice of experience.
Thanks
Sounds like the window regulator. If you search for "regulator" you find your answer on how to repair. Contact Bill Jenkins at Team Ford, www.teamfordparts.com. He can probably get the cheapest price for you.
