Rear window moisture out of control
SALVAGE LS
NEW BRITIAN
Anyone know of any spots in the trunk that could cause this. Its just my rear window and i had it checked its perfectly sealed. Just wondering if any one here is having the same problem and what they did about it. My tail lights look good no water spots or marks. Any help would be great thanks
Check the spare tire well, it might be full of water. The trunk seal is notorious for leaking. Just replace the weatherstriping around the trunk and you should be all set. I did and no more water in trunk. But my rear window never fogged up so it could be something else all together. Possible rear door seals?
