gdubya
Based on the opinions on my 97 Conti intermittent starting issues, I am going to replace the fuel pressure regulator. I don't have a fuel pressure gauge or anything to hook up to the schraeder valve to capture the fuel and relieve the pressure.
Can I just start the car, and then activate the fuel pump cutoff switch in the trunk and let it die? Will that lower the pressure enough for me to work on the regulator? Will this cause any problems? Some other way I should be doing this?
