Cody
Hey guys, last week I blew a hole in the plastic bit of the upper radiator hose. The car had been overheating for a couple weeks, but thought it was low coolant. Well anyways I replace the hose, and now a week later (last night) my car started to overheat again. I was able to use the heater on full blast to help let off some hot air, and cruise my way home. Once home, my car was leaking and steaming from the center of the engine.
What is most likely the cause if the steam is coming from the midline of the motor, sort of under where the MAF and the intake manifold are? Is the water pump down there? I also was hearing some weird squeaky noises which could point to the water pump as well. Im sure all the plastic cooling pieces are on their way out....at about 50k miles ago I did the Throttle body, and at the same time did the thermostat and housing because it had taken a dump on me.
