ZacUnknown69
Hello everyone, as you know the Mark VIII came with a 3.08 and I feel like it holds back the power. I want to swap it with 4.10's, now I know virtually nothing about differentials so bare with me. Do I need to replace ALL the gears, or can I just do the ring and pinion? If all I need to change is the ring and pinion, can I do it at home? Or do I need special tools, presses, etc? If it's more complicated than that, could someone kindly direct me to where I can purchase a Ford 8" 4.10 LSD as a whole? Or a suggest a high geared LSD that would work with my car. Also, if you're up to it, giving me a basic run down of what I'd need to do would also be helpful (I have the full shop service manual, so I can connect the dots) Either way, I appreciate the input. Thanks!
