Replacing mark VII mirror
cdnpt
Ashland
Hey, recently picked up a driver's side mirror, Will I have to pull the door panel to replace it? Alo, the driver's door panel pushes in when I roll the window down, and I notice iti is coming away from the door due to broken mounting tab holes in the panel itself, any thoughts on where to find a new panel?
You will have to pull the door panel to access the wiring harness. Take note where the factory routed the harness before you remove it. Haphazard polacement can result in a cut harness during window operation. You will need to find a new panel off eBay or a junkyard. The mounting bolts (3 7/16 or 10mm) are behind the black, triangular trim piece.
