its not that bad
i had to take my fenders of when i put my lambo doors on. let me see if i can tell you where all the bolts are. under the hood, ther are three or four. you must then remove the black lining in the wheel well. there are two that connect the bumper to the fender, there are two in the inner front door jam by the door hinges. you must remove the plastic cover abover you lights, then you must remove the headlight on whichever side. now there is a cross brace/bumper that is in front of the car, you will see it when you take the headlight off, there are two bolts on it one on top and one on bottom, a little harder to get to. when you take these off, pull it forward. there is a little tab that holds the fender in place. i think thats about it. tools you will need, socket, ratchet, definitely an extension or two. the two that connect the bumper to the fender you must go from the bottom and not really any room.
