Well, you should fix it first. Then disconnect the battery, pump the brake pedal 10 times (just to get all the energy out of the car, capacitors and such) reconnect that battery and you should be good.
Mine did the same thing. I bought a $75.00 tester from Napa. Check Engine light came back. Ignition Coil went bad. First code was bad 02 reading. the tester clears the codes.
