Resting the CHANGE OIL warning... whats that sound
kudisbetta
USA
I just changed the oil and the damn screen still flashes CHANGE OIL. 0 percent. I tried to reset it but it only resets the AC filter.
How do i reset it?
Also recently i noticed this weird sound while driving. i dont know if its the transmision or a little hole on the exhuast.
Its sounds like a z28 at idle when i drive on the highway, its kinda annoying, i first thought it was the tranny, gone bad, but then thought there might be a hole in one on the exhuasts from scrapping the driveway a few times..
what do you think
I thought you just held the reset button when it says 0% and it would reset right then.
I hold reset and everythin resets but the oil...
Im wondering why
tap reset button
first hit the status button. Then when it flashes the oil being at 0% tap the reset button. Then it should say hold down to reset. You then hold the reset button and it should reset itself.
yes, hit status, hit reset then release and hold reset again till it beeps, gotta do it quick or you will miss it and it will reset the ac filter.
what kind of noise? is it? a buzzing noise? or an exhaust noise?
Jay
