Aug 13, 2014 #1 D Donn LVC Member Joined Aug 5, 2014 Messages 17 Reaction score 0 Location red bay What is causing my car to hit rev limit at 3000 rpm. I do have a misfire code p0303 and wondered if that may be the reason.
Aug 13, 2014 #2 chris2523 93 Mark VIII Joined Nov 8, 2007 Messages 7,920 Reaction score 276 Location Central MO don't rev the engine in neutral or park. and you probably need coils. change the plugs too since your there.
Aug 13, 2014 #3 D Donn LVC Member Joined Aug 5, 2014 Messages 17 Reaction score 0 Location red bay chris2523 said: don't rev the engine in neutral or park. and you probably need coils. change the plugs too since your there. Click to expand... Well I wondered about that, but it also hits the limit going down the road in drive.
Aug 13, 2014 #4 RigsLS Dedicated LVC Member Joined Mar 10, 2012 Messages 7,734 Reaction score 523 It's called a misfire, feels just like a rev limiter.
Aug 13, 2014 #5 joegr Dedicated LVC Member Joined Dec 10, 2005 Messages 21,601 Reaction score 2,390 Location Gulfport Failsafe cooling will cause similar symptoms. You really should fix that fan first. (and then replace all the coils, plugs, and the PCV valve)
Aug 13, 2014 #6 FDR Dedicated LVC Member Joined Jan 20, 2014 Messages 2,049 Reaction score 172 Location Central NJ
