Every 6 months or so i'll get back outside and turn the old lincoln over just to keep it on life support.. and i revisit this same old problem that forced me to abandon it.
dash cluster with intermittant going out would cause the car not to crank up.
bought a replacement cluster on ebay, plugged it up, everything works and stays on, needles dont jump or the cluster doesnt go out... BUT of course, the PATS code in the replacement doesnt match the PCM/keys, etc so it doesnt crank. Ive gone so far as to resolder everything on the old cluster just in case a connection cracked..
Has anyone figured out how to bypass the pats with a new cluster without taking it to ford for reprogramming? Does anyone have a pinout wiring diagram of the cluster for 2003? Im interested in retracing everything to see what i can replace or what wires to play with. I dont wanna sell it because it still runs good, i drove it around today until i turned it off, then it wouldnt crank back up... Seems like the more i drive it with the old cluster, and the hotter it gets, the more it starts to act up. Might toss it in the freezer for a day and see what it does after i plug it back in, lol. another idea i had was, swapping whatever CHIP the pats code info in on, onto the new cluster, but i dont know what rom chip holds that data, any idea?? I do have experience resoldering SMD chips and components.
Any advice on bypassing the pats and or hot wiring this car would help.. I have a good cluster and the bad cluster to work with... Or if anyone knows a good online cluster repair person, let me know.. thanks
heres the video again of the cluster acting up
