Ahmad
My key fob doesn't unlock my vehicle until i unlock my trunk then i can use the key fob to unlock the doors. But after like 30 mins or so i have to repeat. Do i need to replace the antenna? And if so where is it located?
Sounds more like a power or module problem than an antenna problem. The RF receiver is in the DDM (Driver's Door Module).
I believe it's inside the drivers door. Remove the inside door panel.And where is the location of the ddm please?
Yes, the Driver's Door Module is in the Driver's door.
Thanks!
Does new ddm mean new door keypad code?
Yes. Also, if you have a 1st gen, you will need a good scan tool (maybe Forscan can do it?) or a dealer to program it for your remotes (key fobs).
Before throwing another DDM at it, I would verify that constant power feed to the DDM is good, and check the rest of the signalling. It sounds like it is failing when the car sleeps and the REM turns the SSP relays off.
