mrcastrovinci
Hi All,
I have a 2004 lincoln Aviator and am having a rough idle ( almost sounds like one of my diesels. I changed all of the plugs and coils. Previously I had a misfire in 6&8, but the new coils cleared the code and it drives fine just rough idle. Here is what I have done so far:
Compression test on all cylinders - Two of them (driver side) seemed lower then the others but according to the ALL Data TSB are within 75% of each other (barely) ALL at or above 148
leak test - No signs of leaking
New plugs, coils
Replaced a few vacuum hoses
Ran fuel cleared
Ran throttle body cleaner
Two issues I noticed:
I noticed a ticking noise up top which sounds like to me a timing chain or lifter.
Oil was found in some of the spark plug locations.
Can you help point me to the next direction? It seems to drive fine
New plugs, coils
Ran fuel cleared
