Running lights stopped work. NEED HELP!!!
Callencampbell8883
TIGARD
Im having issues with my taillights. Running lights to be exact. Ive checked fuses, bulbs and the switch all seem to be working.
I jumped the two brown wires on the back of the headlight switch and the lights turned on but the jumper wire got real hot.
So I got a new headlight switch and nothing changed.
Then I put power to the brown power wire at the socket and grounded it to the chassis and nothing. But when I grounded to the black ground wire at the socket and they lit up.
So im thinking its got to be a ground somewhere between the switch and taillights....
Does anyone have a diagram with the ground locations?
Sent from my SAMSUNG-SM-N900A using Tapatalk
Check the left trunk hinge. There is a harness there. It often breaks and can mess with all sorts of things.
Will do, Im gonna do a continuity test to see where tomorrow. I hope its easy
