Rust on rear 1/4 window dividers 98 towncar
purelux
The 2 smalll posts dividing the 1/4 or so of both of my back windows has rust inside and out on the top on both sides. On the outside it is bubbling under the rubber on the inside it seems to have split open the rubber a bit. I was going to get a 4 or 6 piece chrome set to replace the front ones that are peeling a bit. And figured get a 6 and do the back as well till I noticed the rust. Anybody know the best way to fix it? Is it possible to sand off the rust put on rust killer and seal it below the rust. Or would would need to be done to replace the divider if it by itself can be replaced?
Thanks
