Ken Nevins
Our beautiful '94 MKVII Driver's Door is sagging lower and lower! It is hard to latch, you have to really slam it to get it all the way shut. And it still indicates "Door Open" and the power lock chatters it's displeasure as you drive over bumps. It's obvious the exra heavy door has just worn out the hinge assembly. I say "assembly" because apparently this hinge is not rebuildable like a typical FoMoCo hinge that you can get an aftermarket repair kit for. Have any of you hot-shots been through this problem with your MKVIII's? I need a hand here! Thanks, Ken
