SCIL problem? Twice now lost power to specific things
Bangster
Tucson
This started happening after I replaced the OEM Ballast and HID bulbs with aftermarket. I cut the connectors off the the OEM ballast and crimped them to the 9006 harness I got with the HID kit. I used crimps that have heat shrink on them and shrunk them, and electrical taped them anyways. It isn't raining, temps in the 70, now the 50s.
Tonight after starting the car and turning on the headlights, putting the car in reverse the head lights turned off, the dash lights, etc. It remains running, but I know when I turn it off it won't start back up.
The following things do NOT work:
anti-theft (message center doesn't show anti-theft)
starter (won't start with turn of key, but probably PATS?)
headlights
parking lights
dash lights
interior lights
power windows
trunk pop
message center
windshield wipers
radio
what works:
fuel pump (I hear it prime)
dash idiot lights (traction control, battery, etc)
power door locks
blower motor
EATC
If I disconnect the negative battery cable and connect it again, then things work again. This has happened twice, once right after doing the headlights, and again tonight. I have only driven it 250 miles, mostly at night, since doing the headlights.
I left the OEM ballast in place, the feed to it is cut, and the outputs are still attached to the radiator support. I had to root around the drivers corner of the bumper cover because I dropped an extension with a socket, and I think there is a major wiring harness there maybe?
I use a volt meter and checked power to every fuse, and every fuse had 12.2 or more volts on each side (input and on other side of fuse, so if it is was burnt out it wouldn't have any volts), both in the I/P block and the high amp block under the hood. I also removed any dealing with SCIL and visually checked them and did an ohm test as well.
I don't have auto lamp on, unless I time it just right the headlights turn off during crank and don't come back on. The battery seems to be in fine shape, and the cables look solid, no corrosion. When this isn't happening it cranks solidly, I did the WOT while cranking so it won't start at an oil change and after 4 crank no starts to get the oil pressure up, it started fine.
When it happened the first time I disconnected the HID setup and it didn't help, I had to pull and reconnect the ground cable.
Any ideas? I am not sure what I am missing with the headlights, unless they are drawing too much power or something, it doesn't seem to be when igniting, but much later, I am pretty sure they are up to full temp by the time it happens. It also doesn't blow any fuses.
I've had that problem before. Check and clean the headlight grounds on the front of the core support. 1 on each side. If that doesn't work, I'd run a relay harness to power the ballasts.
