sensatrac 5965 question
aggiestckl
doylestown
alright, i chose to burn out my upper rubber and go with sensatracs 5965's i put the struts and rubber in, and it looks like it squished the rubber bushing real good.. to i continue to tighten the strut until its as tight as possible and keep squishing the rubber or is their a torque spec you guys used on this
i think it calls for 25lbs, but i couldnt get it, mine ended up pretty squished up too, i couldnt get my torque wrench to click so i just kept going till they looked good lol........
i just squished mine as much as i could, seems to work ok
I did mine like I used to do when cars had shocks on all four corners, tighten it down till the rubber bushing is even with or a little past the washers. If you tighten it too much you loose the cushion effect.:) :)
