steagle
Hey guys, I have a feeling my 02 Sensors are bad, but there's the possibility it could be something else malfunctioning that's sending the wrong codes to the sensors. First my air bag light flashes when i start the car then remains solid for the duration of the trip. Then my check engine light was coming on, until I took it to Autozone, got an error code printout, and now the engine light doesn't come on. Do you think the idiot at Autozone erased the code when he was still plugged into the port?? If so that's going to make it harder to troubleshoot unless something was stored in memory... at any rate here's the printout from Autozone:
TROUBLECODE OBDII (ALPHA) P CODE
TROUBLESHOOTING P0430
The PCM has determined that the catalyst system efficiency for Bank 2 is below threshold for the current engine operating conditions. (Bank 1 identifies the location of Cylinder #1, while Bank 2 identifies the cylinders on the opposite bank)
If any of you have had this same code before let me know what you did... I don't want to drop the $200+ to change sensors if that's not what the cause is... should I get it fully checked out at the dealership?
