Set of headlights....up for grabs...
00ls5spd
Bonita Ca
Since I took my projector headlights apart I have a set of headlights that I don't need anymore. They don't have the reflectors though because I had to modify them to fit the projectors. I think this would be a good set for someone to paint the bezel to match their car. The lenses have the gen I vinyl eyebrows on them but they should be easy to remove. The lenses are clear, but do have the normal pitting and road dings in them. I will just take the best offer. I will post pics if needed.
I will post pics tomorrow morning, Sorry for the delay but my home computer has decided to kill itself, (over heating processor issue) So I have to post the pics at work.
they are pretty much stock headlamps with clear corners.. depending on the scratches and pittings.. i'll pay top dollar..
also.. what color is ur car?
Pics....
Here are the pics Yeah they are pretty much clear corner headlights just without the center reflector. It would be an easy swap from your headlight to this one. One of the black rear housings had a crack in it when I recieved them, But I epoxied it closed and didn't have any problems with fogging. Also one of the mounting tabs on the driver side housing was broke off, may have happened in shipping. I epoxied it as well and it has held very good. I just want to let everyone know about the little problems with these lights. I used this set for about six months with no problems with fogging or anything else.
Banginls...My LS is silver frost metallic
headlights 001.JPE
headlights 002.JPE
headlights 003.JPE
headlights 004.JPE
headlights 005.JPE
headlights 006.JPE
headlights 007.JPE
jus wanted to know what color the eyebrow matches.. ok .. im interested.. how much do u want?
to clarify
The reflectors I am talking about are ot the amber turn signal lenses. They are the high/low beam reflectors. I will take $60.00 for the set. you can easily swap your reflectors or do the idea I suggested above and have a second bexel to paint the exterior color of your car.
