Signal flasher?? (searched)
gt95coupe
Chattanooga,Tennessee
I have a 02 ls and was wondering where the turnsignal flasher is located? If someone could point me in the right direction on replacing it. I need to get a shop manual but havent.Is there an online manual? Thanks (checked the owner manual but there was not a listing) Danny:L
If you are talking about yourfront turnsignal bulb its in your headlight, you will have to take it out to get to it.
No Not the bulb the flasher usually located on one of the fuse blocks but I could not find it and it sounds like its coming from behind the instrement cluster but not sure
I believe it's intergal to the cluster.
gt95coupe said:
Can it be replaced?
It can, but it's costly. You would need a new cluster and have your dealer download the information (like mileage) into the new cluster. Clusters can be had from ebay.
Is your blinker not working??? Warranty should cover it if that's the case.
I did not know that. If that is true, that is the most assinine design I have ever heard. Even electronic flashers (compared to the old heat and release style) and go bad.
