Smelling Gas Inside Car
could be an exhaust leak, if you are running a bit rich. but it really could be a lot of things.....
I smell the gas while I am at cruising speeds. Roughly around 45-55mph. Usually when I gas up, I fill it up completely. The only things I've done to to my Mark as of late is change the spark plugs, wires, and adde Magnaflow mufflers. Where would an exhaust leak come from?
Okay, cause one time the gas lever didn't click off on time in my car and it seeped out the top and caused my car to smell like gas for month.
It could. Mine was clogged and I had odors on the highway, until I replaced the filter. It started fine...
Have you had the gas tank down for ANY reason lately, or had the tank itself open for a pump install or anything like that? :Beer
It could have been if you did fill the gas tank up, till the gas is all the way up the filler tube. You should only fill the tank up untill the gas pump stops, not trying to get every last cent out of and get it as full as you can. When you do that, the tank can be so full and the gas can go threw your vent tube into the EVAP, and fill up the charcoal canister, and when it vents the canister (usually at higher speeds/40-60mph) it can cause a strong gas smell. Or the EVAP might not even be doing its job, and could cause a strong gas smell. Just an idea.....
I haven't had the gas tank down at all. It just started smelling two fill ups ago. I sure hope it stops smelling soon.
On my '93, my fuel vapor line had dry-rotted causing the car to smell like gas all the time, till I had it replaced.
It could very well be a injector seal went.. next time you smell gas open your hood and check the top of your intake all around the fuel rail. if its wet with gas, you need to change your seals.
