yeow, like the guy said 89 is way too high. That's the torque for lug nuts.
Inchpounds for the future.
An extractor may do the trick. Whatever you do, DO NOT snap off the extractor, they are a beast to remove.
Assuming you know how to use an extractor, go slow and easy and probably use some lubricant. I believe we are working on Aluminum and a steel bolt so maybe this will be easy, assuming you have no corrosion.
Some tricks from other websites, melt a candle into/onto the threads, heat the area, touch with candle. Also gentle heat to the surrounding metal may help.
Use a sharp drill bit to make your starter hole. And Ditto, DON'T SNAP the drill bit.
Maybe get yourself a reverse twist drill bit. Often the broken bolt will twist out while you are drilling the pilot hole.
In all cases, I would use a good name brand USA made extrator or drill bit to decrease your chance of snapping one off.
Depending on whether the bolt sticks out from the hole, you might be able to get a vise grip on it.
Last resort other than taking it to a shop, is you might weld a nut ontop of the broken bolt if there is some sticking out. Don't weld the bolt into the hole, should be an unspoken truth.
Good Luck.
Jim Henderson
