I did a coil suspension conversion. T-bird struts are a direct swap for the factory air bags. The rear coils are a direct swap but you need to fab up some brackets to retain the coils in the pockets. I think American Air has something for that.
it's easy, no diagram needed. if you got a kit, it's so easy. we did it in my driveway without a lift on my vii and it's pretty well just as straightforward on the viii's.
no sweat.
you can fix the air suspension for about the same money usually.
I was going to give that same site, Blue. Good info! I like Eddie at www.americanairsuspension.com thought too, good parts, cheap, and limited lifetime warrenty! Good Luck!
