SOHC question....
MarkVIII93
Allen Park
My friend has a 4.6 SOHC grand marquis and he thinks that the head might be cracked. Is this a common problem with the SOHC? I personally dont beleive it, but if anybody knows anything....... Oh yeah it has around 66,000 miles. So I am kinda doubting that the head is cracked. Also, Is head warpage a problem with the sohc?
Upon further inspection, I discovered that there is anti freeze around the o-ring seal of the fuel injector. I beleive the head is cracked:shifty:My friend took it to a guy and said that the SOHC heads are known to crack????
probably the upper intake manifold is shot! common problem with those POS plastic intakes ford made!
Well..... Ihave some bad news. The motor is now hydro-locked. While in the process of hydro-locking the motor. It blew ALL of the injector o-ring seals, and cracked the intake manifold.
