Robert Crain
Well gents, this week I sold my 2003 LS. I want to thank all on this forum for your input, guidance, opinion and encouragement. Without the resource of this forum, ownership of this car would have been far more difficult, costly and much less enjoyable.
I owned my LS for a very long time and used it daily as my number one vehicle. For the most part, it was a very reliable car and required virtually no extraordinary service for the first 100k miles except for the usual replacement of wear items like brakes, tires, etc.
But when the car hit about 150k or so miles, like a light switch, this car turned into a real money pit and I couldn't seem to turn off the spigot. I had to stop the bleeding. I think the tipping point for me was the need to remove the intake manifold just to get to that plastic coolant elbow that resides just behind the thermostat. A much bigger project than I expected. I ended up replacing the entire cooling system just like you guys all said I'd have to. That sucked!
But I did love that low rpm power of the V8 and the gas mileage was very respectable too. I never did have any engine problems as it turned out to be the most reliable part of the car. The car's solid feel and comfortable ride was like no other.
I was looking at the Lincoln MKS as a possible replacement but then learned that with this V6 engine, the water pump is driven by the timing chain. When the water pump's bearings or seals go bad (and they will), antifreeze leaks into the oil and oil leaks into the coolant system. Repair is extensive and costly. I chose not to buy a Lincoln with the V6 engine. Burying the water pump inside the engine makes no sense to me and reminded me of my coolant elbow difficulties with the LS. Nothing but trouble down the road.
Thanks again to all and happy motoring. Rob
