Blueberryyum02
How's it going guys it's been awhile since I have posted but I'm always lurking in and out of the forum. Hope everyone's having a good year.
Now to business 2002 v8 I have been chasing a high speed fan issue while a/c is on. I have done all the usual things as for replacing all plastic new motor craft degas bottle wit brand new cap, dorman lasted me a year took a crap in my drive way was sent a new bottle it took a crap the same day I installed it so I went to motorcraft.
Problem solved.
I have bleed the system countless times, check the clamps on all hoses, found that the ones in the throttle body was loose bought new clamps for them two.
Today I was working on my Chrysler 5.7 changing the coolant hose and fan low speed stopped working so put a new assembly in.
I was filling it up while the engine was running and the first thing I notice was at temp wit the cap off it started to boil over.
So that got me to thinking I pop the hood on the ls let it run till it reached operating temp.
So I took the cap and let it run for 30 to 40 minutes
And not once did it boil over or begin to over heat.
Prior to this test
Have not seen it over heat
The fan ramps up loud and is rpm depended when the a/c is on.
A/c blows cold if I start it up wit temps below 70 degrees ambient
And goes hot if I give it gas.
And will not blow cold after that.
I'm lean towards a possible issue wit the thermostat, or the water pump I put on I want to say close to two years ago is getting weak.
All suggestion are appreciated.
Problem solved.
Prior to this test
