some electrical questions
K*A*B
pemberton
i'm installing an MSD digtal window switch (8969) on a 93 mark viii
i don't have a service manual yet and don't know where anything is on the car
i need a key on power under the dash , a key on power under the hood (very low amperage draw )
i also need to tap into one of the negative wires from a coil pack
Thanks Kenny
The negative coil wire is the coil pack 1 is dark blue and light blue/red w light blue the coil pack 2 is pink and white/red and yellow.
i tried them and the window switch still didn't work properly , so screw it , its not getting used
it feels pretty good with the 75 jets in it , i'll be at atco tonight testing it on the 150 jets
NICE report some times when you get back!!!
Remember, t/c off and o/d off and shift at 6k, you should be ripping through the traps in second but with the spray you should be into second by then.
i always have the t/c off lol
i have an x-pipe and the air box removed with a cone filter now to , et's were the same , but picked up 1 mph , lost a little below 4000 , but it hooks better now
i need a converter pretty bad , what are you guys with 4.11's trapping at (rpm)
i was thinking about some 4.56's lol
