Some ? for a 99 Deville
  • Thread starter Thread starter cadiDADI
  • Start date Start date
C
cadiDADI
Guest
1. How hard is it to change the little light inside the control for the windows?
2. Anybody get the 90,000 mile work out? How much was it?
3. The fuel door use to swing open, now it just opens and I have to pull it fully open, any suggestions?
Thats it! Any info is greatly appreciated.
Reply
Well for your third question, it sounds like the spring for your fuel door has stretched a little and no longer has as much strength, which happens after time. Or the hinge may just need to be lubricated.
The lite inside the power window switch is probably an LED, the hardest part is getting the bulb, then you will need to pull the door panel, pull the switch assembly, and find a way to pull it apart. Should be too hard just tedious.
As for the second one. My GF's sebring convertible is going through the 90k miles workout. Heres the list i compiled so far.
Oil change
Air filter change
Trans fluid change
Gas filter change
Spark Plugs
PCV valve
Cabin filter
Grease all suspension components
Radiator flush
New belts (dont forget the timing belt)
Im sure i forgot something but thats off the top of my head for now. Probably around 200bucks or so.
