Sound Deadening
fossten
Louisville
Ok, guys, I have my FatMat roll and I want to do this right. I want my car quiet on the inside. I've already cut pieces for the doors on my 93, but what kind of mentality do I need to have here? does every square inch of metal in the car need to be covered, or are there strategic areas that make the most difference? I also know I need to get some spray for some tight spots.
Help me out anybody...
Did the Mk VIII come with dual door seals?
All I've ever done on friends cars is to mat the doors/firewall/ceiling. The trunk doesn't need it unless you're running heavy duty stereo equipment and you're concerned with Db loss. Otherwise just seal up the rear seat area real good with foam strip or weather strip...something like that.
But then again...I'm no expert...just another shadetree.
